Okay ladies and gentlemen of great wisdom and knowledge, I have a question for you! Today on a ride my right fork seal decided that it was no longer going to play by the rules and let a lot of fork juice get out. I'm getting ready to order new seals etc. and I wanted to ask about making it better!
I know that the CX500's benefit from some spring spacers and ATF fluid but what about CX650? Should I just put it back together stock? Should I put spacers in it? Should I get better springs? How about the fluid, do I use ATF or fork oil?
Any suggestions are welcome!
Thanks guys!
If the damping was half decent I wouldn't bother with the spacers but i would NOT use ATF, get some 15W or 20W fork oil.
20w Belray fork oil. Maybe a light spacer if it needs it but if you feel they are fine right now then no spacer is needed.
After working on my forks and trying spacers and 20 wt Belray (which I liked) with my stock springs, I sprung for Progressive Fork Springs, and I am glad I did. Better than stock, stock with spacers, etc. I was running the Progressives and 20 wt Belray but switched back to Dexron ATF. Damping was a bit harsh with the 20 wt for me, smoother ride with the ATF for my ride to work and back (bumpy roads). Handling tho was a bit more sure footed with the 20 wt. Perhaps I will try 15 wt fork oil for a compromise.
BTW the spacers (pre load) affect ride height mostly, while the oil weight affects damping and ride quality. Oil level also affects ride quality. I am using no spacers and no added air pressure with the Progressive springs, and I have increased my oil volume a bit above stock to decrease the volume of air above the fork oil. I am still tweaking the forks but I have them just about where I want them. I also changed the oil in my rear monoshock, which really helped the ride quality quite a bit.
