101 - 111 of 111 Posts
Discussion Starter · #101 · (Edited)
Piston as removed with no cleaning performed. Looked like new!
Auto part Automotive tire Rim Wheel
Main bearings looked and measured good.
Wheel Auto part Rim Automotive wheel system Tire
Auto part Wheel Automotive wheel system Rim Circle
Reactions: CXPHREAK
Discussion Starter · #102 · (Edited)
Connecting rod bearings looked good and oil clearance measured in spec using plastigauge.
Material property Finger Cylinder Metal
Auto part Wheel Metal
Rod side clearance measured ok.
Auto part Crankshaft Gear Transmission part Drive shaft
Main journals looked good and measured within spec.
Auto part Metal Crankshaft
Discussion Starter · #103 ·
Cylinders cleaned up nicely, measured well within spec and were honed.
Arm Machine tool Auto part Machine Metal
Rim Alloy wheel Wheel Auto part Automotive wheel system
Reactions: CXPHREAK
Discussion Starter · #104 ·
The gear box was disassembled, inspected, measured as required and reassembled.
Parts looked all good. Assembly was a challenge. I should have taken better notes during disassembly.
Bicycle part
Auto part Metalworking hand tool Tool accessory Machine tool Machine
Reactions: CXPHREAK
Discussion Starter · #105 · (Edited)
Engine cases were thoroughly cleaned and prepped for painting. Painted all cases using can's of engine enamel and primer from DUPLI color in my drive way.
Green Costume Plastic Plastic bag Fictional character
primed
Grass Tree Lawn Sculpture
painted
Sculpture
So far no problems with the paint, it seems to hold up well.
All the prepping was done by hand. I did not media blast any parts.
Discussion Starter · #106 · (Edited)
Setting valve timing on cam shaft.
Auto part Engine Bicycle part Wheel Automotive engine part
Setting valve timing on crank shaft.
Bicycle part Bicycle drivetrain part Auto part Groupset Crankset
Installing chain, tensioner, guide and guide plate.
Auto part Bicycle part Engine Automotive engine part Gear
Discussion Starter · #107 · (Edited)
Cylinder head gaskets coated with Permatex Copper gasket spray on both sides -ready for installation.
Design Circle Metal
Text Product Font Material property
Don't forget the oil control orifice, small O-ring and dowel pins.
Auto part Engine Automotive engine part Machine Metalworking
Reactions: CXapatite
Discussion Starter · #108 · (Edited)
Found a set of leather saddle bags on ebay from a supplier in India (free shipping). The bags showed in about two weeks and appear to be well made (goat leather).
I had a set of hard luggage carriers that actually came with this bike. Two of the three attach points were still usable (rear foot peg and upper shock mount). Fabricated a brace for a third attach point on the rear fender.
Leather Brown Satchel Bag Messenger bag
The bags came with three leather straps in the back for mounting. I wanted a 4 point attach allowing for a more secure bag mounting and quick disconnect.
Pop riveted two aluminum bars (top and bottom) to the inside of each bag. Each bar has two mounting holes picking up the luggage carrier attach points. Used large washers under the rivet heads.
Brown Leather Metal
The multi-hole clevis pins penetrate through the aluminum bars and bag to pick up the 4 luggage rack holes.
Cut leather straps to mount between bags and luggage rack for a "soft scratch free attach".
Brown Leather Tan Metal Furniture
Used a large nut and washer as spacer and a quick pin to keep it all in place. The bags can be removed and attached in seconds. They are solidly mounted and don't move at all when driving at highway speed.
Here is the bag attached to the frame.
Leather Bag Fashion accessory Metal
And here is the final product installed.
Motor vehicle Vehicle Motorcycle Automotive design Motorcycle accessories
Land vehicle Vehicle Motorcycle Motor vehicle Fuel tank
Very cool bike.
So while perusing the net I happened upon this forum and thread.
As it happens, my bike is also of a similar style as well and also a 500cc Honda albeit the earlier parallel twin version.
I hope you don't mind me posting this on your thread.
The similarities of our bikes are uncanny. I can't believe I haven't seen yours on the road around Seattle yet since we both are from the area.
198787
198788
Discussion Starter · #111 ·
Very cool bike.
just seen that. Haven’t been on the forum for a while. Was busy restoring a 1972 CB450.
Beautiful bike you got. Very similar to mine.
