Tire Fuel tank Wheel Vehicle Automotive fuel system
Tire Fuel tank Wheel Vehicle Plant
Tire Wheel Plant Automotive lighting Fuel tank
Here's my '78 cx500 cafe racer project I have been working on over the past few months. I got it for free from a buddy and learned that a free bike is the most expensive bike. Swapped front end, Ray-San ignition, Murray's carbs, and a few other upgrades. Still a work in progress
And welcome to the world of antique vehicle ownership (they own us, not the other way around). Your bike is about 4 decades old and in spite of all the work you have done may or may not have had all of the maintenance necessary to keep it safe & reliable so it is highly recommended to download the Factory Shop Manual for your model (available through the CX Wiki - link in my signature) and go through all of the service procedures, regardless of whether your bike has reached the specified mileage.
I also recommend looking on all rubber parts with suspicion because rubber does not age gracefully. Check the date codes on your tires and replace them if they are over 5 years old no matter how good they look & feel (old rubber simply cannot flow around the irregularities in the asphalt well enough to grip, especially if it is cool or wet). It looks like your bike still has the original type rubber brake lines, which should be replaced every 2 or 3 fluid changes (= 5 or 6 years) so I recommend shopping for modern stainless braided ones (they last practically forever and double the life of the fluid). And don't forget things like the rad hoses and the boot between the engine and swingarm (they can crack on the bottom where you don't see it).
