1 - 2 of 2 Posts
there is a key code for each lock and key. my understanding that there were only a certain number of codes, so there should be duplicate keys out there if you can determine the code. In any event, if you know the code, you can get a new key cut.
The code is written on the underside of the gas cap also. Of course if all your locks are still a matched set, you can get the key code of your ignition or helmet lock also. if yourgas cap s is locked on the tank, if you take it off the bike and drain it; then remove the fuel float, I believe you can look up with a flashlight and see it (the code).
another option would be to go in with one of those digital camera snakes to help see it. make sure you flush it out good if you intend to go in with anything that may ignite gas fumes. Be careful.
Once you the code, you can have a key made.
1 - 2 of 2 Posts
