1 - 10 of 10 Posts
Hi,
I've just taken cover off my 1979 CX500 and found a 30cm rubber pipe (external 10mm and internal 5mm) with no clip marks on floor underneath it. I don't know where is goes can anyone help please?
Thanks in anticipation
best wishes
Mark
One of the drain hoses perhaps. Float bowl drain, battery drain?
Ahh yes I took battery out so probably fell off when I did that thanks so much really helpful and appreciated
Length and diameter sound like a fuel line to me.
Breather hose? Maybe disconected and plugged at some stage.
Maybe get the bike in daylight and look for any inlet/outlet open to air....then post a pic....(if unsure of connection)
Yes. Please post a photo of the hose so we can see what you are talking about. And which cover did you remove? (that could be a big clue).
Welcome to the forum. Please add your location and your bike's model and model year (NOT year first registered as UK paperwork shows) to your profile so that you don't have to remember to tell us every time and we don't have to keep asking when you forget (see Forum Settings link in my signature).
Hi, Thanks for all help - it was the battery breather pipe so easily fitted back on. My battery went flat so took it out to charge it up and must have fallen off then. Anyway battery now charged, pipe back on and went out for lovely ride to Cheddar Gorge this afternoon and bike was running beautifully so all good.
Thanks for welcome to the group. I love my CX500 - 45k miles and totally original although chrome a bit rusty as have to keep her outdoors and she doesn't like our winters.
I'll add my bike details for future reference as you suggest Bob thank you. I do have a Classic Japanese Motorcycle repair shop only about 10 miles from where I live which is brilliant. Its called Alpha Motorcycles and they are fantastically helpful.
best wishes
Mark
1 - 10 of 10 Posts
