I stalled the bike recently and the starter would only work in neutral. I think it should start at any time with the clutch pulled in. Where do i find the switch that allows that without the bike in neutral ?
On the clutch lever housing.
Post 3 here.
Easy way to test it is to remove the wires and join them together to bypass the switch and see if it'll spin in gear. {don't forget to pull the clutch anyway}.If it spins over it's the switch.
Or you can continuity test the switch.
Post 3 here.
OK Thank you. Will go and look for it.
