Hey guys me again, I finally got past the last major hold ups around my CX (like the majorly damaged water pump mechanical seal, don't know why I thought it was still OK to run) but she still wont run except on ether.
She kicks once or twice if I let it sit for a little while but it seems like there isn't enough gas coming from my pilot jets or maybe getting to them, I don't rightfully know which jets feed the engine on start or what might be causing this issue. what I do know is that I have gas in my carbs, I have spark, my timing seems to be fine, and she'll rev like a demon when there's some ether in the air but I do not believe that there is enough gas coming from my carbs, I've adjusted the little brass screw up front from fully closed to wide open but nothing seems to get it to kick.
Sorry if I'm explaining this poorly but basically I got gas in the bowls, I have spark, my timing seems correct but it only seems to fire when without ether is if I let the bike sit for a few minutes which I believe is because there is something slowing the amount of gas going through my carbs.
Thank you guys for what ever help you've got, feel free to ask for more clarification.
