just picked up a 79 CX500 with 30k miles on it . I'd like to give a big shout out to all ye CX500 owners ! I've already met alot of you online
has the CDI ignition , things i've checked are . kill switch ok , starter button ok sending voltage to the yellow/red wire to solenoid when i push the start button(new Starter Solenoid coming in mail this ones not working) . when i jump the solenoid she cranks over fine but i get no spark .. shouldnt it be sparking? pulled plug and have it grounded to bike at a good ground. also i have cleaned the ignition coil connections on both coils to make a good ground. so my question is shouldnt it be sparking by jumping the solenoid? These are new NGK plugs .. old one not sparking either. I did also check for voltage at the coil wire connection before coil to see if getting any voltage to it .. nada. oh and i also did check the flywheel through the timing hole on the engine to make sure its turning .. yup its turning.
also i have read about the neutral switch . i do get a neutral light when electric is on . that wouldnt make it not spark would it? also checked the pickup coil continuity o/w wire to lt blue/white wire on the engine side. i also checked for some AC voltage at these wires when cranking by jumping the starter relay and its getting voltage there. Its cranking over fine , i even tried to jump it with my car battery still no spark so not battery related.
something with the CDI or Stator related me thinks ? oh also i did think of something else . i did have the front head light/instrument cluster on but it wasnt all hooked up with the ground. i have left it off unconnected until i paint it .. do i need that on and grounded right for it to spark ? just a thought , seems to me if i'm getting voltage at the starter relay solenoid when i push the start button it should be ok and crank over and spark eh? i have been wrong before tho .. once i think
looking forward to continuing this CX500 resurrection
.. haha any help apprieciated.
what my bad boy looks like now
Pic 1
Pic 2
when i get done with her it will look like this one
Pic 3
Pic 1
Pic 2
Pic 3
