1 - 8 of 8 Posts
Hey,
I have a 1980 cx500, recently rebuilt the carbies with new jets, pilot screw, o-rings, ect...
It had some scoring on the top section, I think due to I had a rust issue with my tank.
I have just done a compression test on both cylinders and both are at 100psi.
When I start it up it only runs on the right cylinder.
The right carbies has a bunch of vacuum going through it as when I cover the carbie inlet it dies.
The left has no vacuum going through it,
What could this be?
Missing o-ring at the intake port?
Welcome, by the way!
Yes. If there's a large leak there, it might not draw through the carb.
Did you separate the carbs or disturb the linkages between them in any way when you had them apart?If so I'd start by checking them for assembly errors (particularly at the balance adjuster).
Did you check that both throttle butterflies were moving together and starting to open at close to the same time when you put them back together?
How about the chokes?
Where did you get the jets, screws &c that you replaced? The original ones almost never need to be replaced and the ones in aftermarket carb kits are often so far out of spec that they can have adverse effects on tuning the carbs. They probably aren't causing your current problem but if you have them apart to fix this it might not be a bad idea to either put the original parts back or get replacements from a Honda dealer.
Welcome to the forum. Please add your location and your bike's model and model year (NOT year first registered as UK paperwork shows) to your profile so that you don't have to remember to tell us every time and we don't have to keep asking when you forget (see Forum Settings link in my signature).
Yes I did separate the two but I was very careful to video and take photos of everything so it was put back together correctly, also the throttle butterflies are moving together, the choke also it connected and move together.
I have rejetted it for a more flowing exhaust and pod filter for the intake.
I will try and figure out how to put a signature in.
And yes I plan on upgrading break lines to steel braided, I also have a 1982 cx500 sport that I'm going to do the same to.
As I said, the Forum Settings link in my signature takes you to instructions for adding the information to your profile so that it will show up whenever you post (note my bike's model & year below my name and if you mouse over my name or avatar pic you will see my location and forum stats.
It is pretty common for people to get the washers &/or spring of the balance adjustment in the wrong order, but if your throttle butterflies are opening at close to the same time and the chokes are both open the only other thing I can think of that would block airflow through one carb is a stuck slide. Tell us more about what you mean by "It had some scoring on the top section"
1 - 8 of 8 Posts
