Hello all,
Looking for some advice. I just finished cleaining and rebuilding a used honda starter motor for the CX500/GL500 (and probably many other models). When I received it, it was obvious that the previous owner had taken it apart. I applied 12 volts to the post and grounded the motor body to negative on a charged (13.8V) lithium battery and got nothing..no sparks, no smoke, but also no running starter motor. So I elected to rebuild it complete with new electrical plate, brushes, fiber washers, seals etc. When testing the components for continuity prior to reassembly this is what I found:
- On the armature/commutator there is continuity between both ends of the shaft, and from both shaft ends to the main armature part in the middle (shiny silver metal middle section). There is NO continuity between the armature shaft/ shiny metal middle section when tested to the copper commutator where the brushes ride on. I think this is the way it should be, but would like confirmation from you all if you know.
So far so good I thought. However when I assembled everyting together, The motor made no effort to run when 12 Volts was applied. Furthermore, there IS electrical continuity now between the HOT + post and the starter motor body, which to me seems like a dead short.
Your thought/comments would be much appreciated.
Cheers
JP
- the body with internal windings had no continuity between the positive lead and the metal body itself
- there is continuity from the body positive lead to all individual copper elements that make up the internal winding cicuit
- there is no continuity between the two brushes mounted on the electrical plate
Cheers
JP
