1 - 3 of 3 Posts
Do you mean brackets 2 and 3 or on the frame?
Where are you located? Put it in your profile so people can help out better.
I checked out your blog -- way cool!
Regarding your frame build, you may want to check out a GL500 frame instead of a CX500 frame. The difference is that GL500's have a monoshock instead of the conventional dual shock CX500 arrangement. Lot's of these bikes were made so you may be able to pick up a frame at a nearby junkyard or perhaps a CX/GL500 forum member with a spare frame is nearby you. Where are you located?
1 - 3 of 3 Posts
