It a matter of positioning the electric fan on the back of the radiator so it doesnt foul the protruding cam snout. There are more than a few fans that fit , measure the space then go looking for a fan
That is good to know for sure, but where are you located and what kind of riding do you do? The reason i ask is i was all gung-ho about the e-fan conversion due to stories of grenading fans (even brand new ones) but am now hearing stories like yours. I don't like the idea of hacking off the end of the camshaft, it's irreparable, but don't like the idea of fan shrapnel destroying the rad either.i bought a 1995 Kawasaki Ninja fan expecting to do the same thing—but requires cutting off the end of the cam, so i just bought an original fan instead. I don't have overheating issues, so no need to go 'lectic i think.
Think there is some variation in guages or 7v regulators. Mine runs close to what is in photo. Never had an issue? Any higher than this and I would be concernedI agree with Phreak, you have a problem other than your fan. How is the condition of your radiator? My Silverwing never got that hot when in the desert in New Mexico at 100 degrees plus.
There very well could be variations in gauges unless his temperature reading is consistently cooler when cruising at speed. A little stop and go and then getting up to 35mph with temps in the 70’s I wouldn’t expect to see high temps that cruising at 50mph. Anyone else have high temp readings? Just curious now.Think there is some variation in guages or 7v regulators. Mine runs close to what is in photo. Never had an issue? Any higher than this and I would be concerned
