Did my 1st carb rebuild about a month back, was stoked(and a lil surprised) I got it running better than ever. After more than 1000 miles, gas began leaking from right carb at the joint fuel pipe. Did not use Honda factory O-rings on fuel pipe, so I assumed that was the issue. Took apart the carbs to check it out, but O-rings appeared to look the same. Why is one leaking and the other just fine? Float needle seems good. There might have been a little oil too. Please help! 馃檹
1981 CX500C
So I actually just came to post a very similar problem. I cleaned the carbs and put the tank back on and everything was fine for a week, left the petcock on the whole time. I'm getting ready to sync the carbs so I took the tank off and made a temporary tank. Once I hooked up the temp tank gas started pouring out at the same spot as you described.
Maybe make sure yours is still attached on both ends.
What I found was that the leak stopped when plugged the vacuum port coming off that right carb. It wasn't hooked up to anything while using the temp tank. I don't really understand why this would cause the leak there but it definitely seems the source of my problem.
1982 CX500C
Did you use lubricant when installing the tube into the carbs? If not it鈥檚 possible the o-ring rolled/twisted while being installed.
Err on the safe side - replace both o-rings again and use lube to install the tube into the carbs. Something greasy (petroleum jelly is what I use) works best but regular oil will do.
Silicone grease is recommended. Also make sure to clean & polish the pipes and the openings they go into because debris or burrs in them can cause leaks.
I would make sure the new o-rings are the correct size too.
Charles: If your petcock has a vacuum line it is a vacuum petcock, which means it has a vacuum operated valve as well as the manually operated one and fuel can't flow unless the engine is turning fast enough to provide enough vacuum to open the vacuum valve. I have no idea why the leak would stop when you plugged the vacuum line but it would be pointless to balance the carbs with the vacuum line open because it would allow air to be drawn into the engine after the carb.
CXchick:
