1 - 15 of 15 Posts
hello, im new here and ive been searching around a little bit and cannot seem to find anything about removing the airbox itself. i am interested in installing pod filters and i just wanted to see if anybody would be able to help me with removing the airbox; what exactly is the easiest way of going about doing this? i took a look around the airbox and im not exactly sure what all i need to do to get it off. any help would be great, thanks! :D
to remove the air box "properly" sigh
take the hoses off the air box from under the bike at least one of them will leak mystery sludge down your arm
take the top off the air box by undoing the 3 million little phillips screws
remove the 3 10mm head bolts that hold the support plate to the frame so it drops down i know you will try it with out doing this but it wont work !
undo and remove the rubber intake boots from the air box
take the air box out of the frame
do the 3 bolts up that hold the support plat back try to remember to put the battery ground back on
undo the front bolt again because you forgot the [email protected]#$%ing ground cable and your bike wont start and put the cable back
have a beer and think about why you didnt use the sawsall like i do
Lol excellent response Murray. You forgot the part where you have to look for the ratchet you just had in your hand for 15 min lol
Discussion Starter #6
thanks alot just what i was looking for!!
The toughest part when I pulled mine out was detaching those stupid hoses on the bottom of the airbox
It shows that he has been using the search function and it adds something for others who also use the search function.
I will have a beer and forget about it!!!!!!:scratch: What did he say ????
1 - 15 of 15 Posts
