1 - 6 of 6 Posts
Hi,
I am new to the platform and to bike building. I chose the cx platform as my first project bike but haven't yet started.
I am after a full motocycle manual for cx500 82 model down to the nuts and bolts which I can use to understand the bike's components, electronic etc
Not the service manual. Does anybody know where I can find this without going to amazon and buying the manual :)
Welcome to the forum. Please add your location and your bike's model and model year (NOT year first registered as some countries' paperwork shows) to your profile so that you don't have to remember to tell us every time and we don't have to keep asking when you forget (see Forum Settings link in my signature).
And welcome to the world of antique vehicle ownership (they own us, not the other way around). Your bike is about 4 decades old and the Previous Owners may or may not have done the maintenance necessary to keep it safe & reliable so it is highly recommended to download the Factory Shop Manual for your model (also available through the CX Wiki - link in my signature) and go through all of the service procedures, regardless of whether your bike has reached the specified mileage. If you expect to do any modifications to the electric system you can also find wiring drawings and the Honda Wire Color Codes chart there.
1 - 6 of 6 Posts
