Hi, are there any other members of this forum that are from South Africa? I would like to have contact with them.
Thanks.
Jacques
Thanks.
Jacques
A forum search for "South Africa" turns up this. I think ghettorider is there, and I would assume SA Biker, as well. Probably a couple more.
R
I am in Durban and am restoring a 1981 GL500 I - need some info if possible. - Eric.i think I smith was from there as well.no my mistake Australia
Hi Eric, welcome to the forum! What kind of help do you need? Take a moment to edit your profile with your location and bike details *see link below*I am in Durban and am restoring a 1981 GL500 I - need some info if possible. - Eric.![]()
My mechanic is taking care of everything the motor is good im going to do the suspension and cosmetics, and go through all the parts and rubbers around the motor, i have done allot of mechanical work in the past, i am the 3rd owner and the bike is older then i am i just love the whole thing, i need to redo the forks as they compress to far down and need to recon the back original shock if i can, i have the factory shop manual for my bike and my mechanic is going nuts over everything i have and he has done a very good job i am getting her back in 2 weeks.I don't know how many CX650Es there are in SA (or even if they were officially imported) but the engine and drivetrain are similar to the GL650 so you should be able to find most parts. What did you have to make.
Welcome to the forum. Please add your location and your bike's model and model year (NOT year first registered if that's what your paperwork shows) to your profile so that you don't have to remember to tell us every time and we don't have to keep asking when you forget (see Forum Settings link in my signature).
