Holy crap!
They replaced the oil pump, rocker arms, cam shaft AND the rings on this bike.
Except for the used stator, you have a practically new motor in that thing.
at least as far as wear parts is concerned.
The rings are know to last 50+k miles.
I have never heard of anyone needing to change their rocker arms before. I guess thay can wear out. but I couldn't guess the mileage.
The oil pump just is not a problem on these bikes. I figure I Might think of changing mine at 90k when I replace the cam chain again.
I doubt very much that this bike Needed any of this besides the stator.
They likely could not Find a new or rebuilt stator available. so needed to buy a used one.
Back in '00 it was hard to find anyone that could rebuild a CDI stator.
I think they found some wear on the bolt inside the cam chain, probably due to poor maintenance, and replace the entire cam chain system.
As for the rings and oil pump. I have No idea.
and the cam and rocker arms.... maybe they found some rust on the cam at the oil seal and decided to replace it and the cam Followers as a set.
I can guess at what Actually happened though.
I think it had a stator failure. there is the "no start" in this list of parts.
Then they sold the previous owner all the rest of this stuff.
It may have had "low compression" and if it was cranking slow, "low oil pressure".
the spec in the manual is 171psi on a compression test. but I have Never gotten more than 150psi during a test on a CX or GL. my GL500 regularly tested at ~130psi. and I put over 25k miles on it and retired it with over 55k miles and Running good.
at less then 1100 rpm, the oil psi is Low. even on a New CX the oil psi would be low at less than 1100 rpm.
If they tested it at crank speeds, I bet it looked Really low. so even if the owner was standing right there looking, they could sell him rings and an oil pump.
I can only guess they showed the guy the "damage" on the tail end of the cam shaft and told him it needed to be replace as a set with the cam Followers, but wrote them down as rocker arms.
It is very common to find some pitting on the cam around the oil seal and water pump seal.
but not actually where the oil seal rides on the cam. so it may Look bad, but not actually have anything wrong with it or need replacement.
In my opinion, you have a bike with a practically New motor and if you have a CDI problem, I would just put a ignititech on it.
OR they never replaced any parts except for the used stator. and Maybe the cam chain.
with only 3k miles on the cam chain that we Know will last 40-50k miles (on a 500, the 650's last 40-45k)
I would try the dental mirror trick to see if the cam chain tensioner is all the way at the top.
if it looks to be at the midway or more wear, I would assume they didn't replace anything but the gaskets and stator.
