I am new to this forum and in need of assistance. Is there a source for the turbo air filter? Also need a clutch cover gasket, the GL seems a might small. Thanks in advance for any info.
DIY - Foam Air Filter As you know, the CX500TC air filter (foam element) is no longer available from HONDA. I fabricated one using UNI-Green air filter sheet foam and some readily available adhesive. Materials needed: Uni - 5/8 inch filter foam LocTite - Stick and Seal Outdoor Adhesive Ruler...
I'm new to the forum as well. I had the same issue with the stock Honda foam filter deteriorating so I cobbled up an adaptor to fit the intake to the reed valve chamber and installed a conical K&N filter. I can provide photos if anyone is interested.
Related Threads
Honda CX 500 Forum
613K posts
34.8K members
Since 2010
