1 - 7 of 7 Posts
What model? - there are three to choose from.
Early black plastic.
Later aluminium.
And a later aluminium one again from the euro with no side reflectors.
Ebay has used ones.....interestingly...new Oem...Nos are popping up...
You could also consider new aluminium aftermarket....i bought one locally for bout $35USD.....(discontinued cafe project.....)....or make your own for little $ materials...
Nice stainless are also to be had....
Welcome to the forum. Please add your location and your bike's model and model year (NOT year first registered as UK paperwork shows) to your profile so that you don't have to remember to tell us every time and we don't have to keep asking when you forget (see Forum Settings link in my signature).
More info needed. I may have what you need. UK
Since the radiator may have been replaced at some point in the bikes history -
If you look at the sides of the radiator you will see two 6 mm mounting holes for the shroud on each side.
If the holes are centred down the side the rad will accept the black plastic shroud.
If they are offset to the front it will accept one of the alloy ones.
Reactions: bahn88
Deluxe 79,80 Custom 81, GL500 81
1 - 7 of 7 Posts
