Well here's how my 79 thats been sitting for 25 + yrs restore is going.....
I hooked up with Stan In TO who was extremely generous and sold me 2 parts bikes. Very knowledgable and friendly guy, thanks again for everything Stan. Ultrasonic on the way from HF. Also met Ironicnostalgia, hope those parts worked for you and you passed your test !
So after carting off the 2 bikes from Stan I cracked into my set of carbs that were totally gummed up. After much Simple Green soaking, carb spray and choice words I was able to free them up, disassemble and give em a good clean(removed all the rubber/plastic first). Used carb spray and CLR and air repeatedly. Everything got replaced, needle, main jets, diagrams, gaskets and screws etc. Floats were ok. Only thing that I didnt touch was the idle jet...I really dont want to have to take that appart at this point as my main objective is just to see if this honey will fire up and the rest of the carb seemed not to bad...famous last words?
So questions.....first off, the rear cover has been off for some time now and dust has gotten onto everything, cover and block. Also looks like a fair bit of gunk? in the lower channels of the block. How should I go about cleaning this? Simple Green? Carb or break cleaner? or just new oil filter and wipe it off? Also, I have a D & K gasket kit to use. I am thinking I may have to remove the rear cover after the "test". Should I use gasket seal? I say in a thread LM grease to be able to reuse the gasket. Also saw someone saying that they do not put gasket seal at all...? And what oil would you say I should use for the purpose of the test? And any other suggestions about this testing.....I am aware of the triple bypass and that will get done in good time, mech seal is on the way as we speak, chains will be down the road.
Thanks in advance guys !
