Started with a practice swing:
Used spring loaded punch to make starting point:
Hole is off center enough whereby I can't get 12mm socket onto the bolt even when angling the socket:
It might make a good sight hole for checking cam chain wear:
Another look:
Bottom of the hole seems not to leave enough lip for a grommet to seal it and I don't see how one could effectively drill any lower or make the hole any larger.
The OD of my 12mm socket is 17mm or very close to it, typical for the 12mm sockets I looked at. I used the 11/16" step from the step bit.
Not sure if I can salvage this procedure. Not sure the hole can be made so as to allow a blanking grommet to seal it at the bottom since there is little to no room for the lip of the grommet. I hit the center of the area where the cover had been milled with the punch or came darned close and the hole is still off. A millimeter or two to the right should center the hole if starting from scratch. In spite of my limited experience with such matters, I say that if the hole can be centered on the bolt and then effectively sealed I think this procedure superior to using an insert. However, given the precision required for centering the hole and questions related to sealing it, I'd say that this procedure is not yet ready for prime time.
Another look:
