1 - 3 of 3 Posts
I've spent the past couple days doing a ton of research about the wiring on my '82 GL500. I've decided to make a custom wiring harness mostly from scratch, as I plan to relocate/delete a lot of components for a cafe build. My main goal is to simplify the harness, and keep the bare necessities as I don't want a rats nest under my seat. I plan to reuse stock connectors for the components I'm keeping, which is the Ign switch, start button, ignition system, and charging system. I'm planning to run my starter, headlight, brake light circuit myself, using appropriate relays/solenoids/wire size, etc.
While everything I plan to do is pretty straight forward, I want to confirm my understanding of the rectifier and ignitor chip wiring. I am aware that the 3 output wires for the rectifier are: Green=ground ; Red=to battery, black=voltage regulator reference. As far as the 5 ignitor chip wires go: green=ground, yellow & blue=input signals, black/white=power, then another blue and yellow (i think) as output signals to coils.
This was a little confusing to me at first, but I'm pretty confident I have everything right. The only thing I'm not sure of is where I can run the black voltage regulator reference wire to. It seems to go all over the place in the stock harness, but from my understanding I'm assuming I can just run it to the battery along with the red and white wire. Could I just connect the 2 together straight out of the regulator? I'd say I'm pretty familiar with general wiring, but I've never really played with stator and rectifier wiring before.
Any help or advice is very much appreciated!!
Attached is the wiring diagram I've been using along with looking at my deloomed wiring harness from the bike.
Also attached is a general idea of what I plan to do with the harness I plan to make.
OG Wiring Diagram
207996
simplified diagram
207995
Welcome to the forum.
Looking at your diagram I don't see a temperature gauge. A temperature gauge, or at least an idiot light, is a vital gauge on a water cooled bike. It is easy to destroy one of these engines by unnoticed overheating.
That is a terrible copy of the wiring drawing; It is small and fuzzy and doesn't even say which model it is for (there are some small differences between the '81 and '82 and between the Interstate and naked models). The '82 GL500 Interstate drawing below (from the CX Wiki) is much better (& we are working on replacing the drawings there with more accurate versions soon - note that the diode is connected backwards and there may be other small errors).
https://motovillage.org/wiki/hondacxgl/images/5/5e/1982_GL500I_schematic.JPG
And for the generic minimalist drawing you posted what amounts to a thumbnail. Here's the full size version. That would get a bike working but it is far from adequate.
208003
It is very easy to "simplify" the wiring by removing circuits but it is very poor practice to render the bike unsuitable for use on public roads in the process:
The temperature gauge Mike mentioned is very important (several cases have been reported on this forum of engines being destroyed by overheating on bikes that didn't have working temp gauges).
It is a legal requirement in the US and Canada to maintain all lighting functions that were on the vehicle when it left the factory and for your GL500 that includes turn signals, front running (marker) lights and brake light switches on BOTH brake systems (front & rear).
Note that the turn signals must be 100mm/4" from any other light that is on when the signal is flashing (this is a good law because if they are closer it is hard to tell if it is actually flashing); Honda were very clever and used front signals with dual filament bulbs for markers & signals and the turn signal switch cuts power to the marker when you turn the signal on. (FWIW, I have separate markers and signals on my bikes with tiny but bright 1W LEDs that you barely notice when not lit on the CX and somewhat larger LED lights on a bar mounted to the GoldWing's lower triple clamp; Since they are more than 4" from the signals they don't need to turn off when the signals are on, which allowed me to replace the ancient & very tired original switches with ones from a model that doesn't have that feature).
That drawing doesn't even include a horn (yes, that is required too).
BTW: If you are going to mess with the wiring I also recommend downloading the Honda Wire Color Codes chart from the Wiki and making every effort to use the same colours Honda used whenever possible to make future troubleshooting easier.
1 - 3 of 3 Posts
