So I swapped out my 81 CX500C forks with a set from a 83 GL650 interstate. I challenged myself in this build to try to use existing parts in most cases. But the new triple tree had no key switch mount like the CX500 forks, so I decided to move my key switch to underneath my tank on the right side. This left me with a handlebar clamp with a empty switch hole, which looked funny. One possible solution was to grind the switch mount completely off, but I thought that would look funny too. So my solution was to construct a small metal disc with carefully drilled holes and basically create a turn signal, neutral, high beam and oil pressure light using tiny LEDs from Ebay to replace the clunky idiot light box that sits between the speedo and tach on a stock bike. After drilling the holes, I welded a couple of machine screws to the backside of the plate and crafted a backing plate to bolt the whole assembly firmly within the key switch mounting ring, painted it with three coats of caliper paint, baked it off, then installed it as shown. Once I installed the light cluster I realized the stock mount for the instrument cluster had the speedo and tach way to far apart without the box between them, so I had to modify the stock instrument cluster mounts to move them closer together. Unfortunately, this picture shows my crappy welds on the mounting plate between the instruments. I guess I need to pull it all off, grind it down better, and re-paint, but it's really less noticeable than in the photo. Also forgive the layer of grinding dust in this pic. Anyway, I did this with my limited set of shop tools...a bench grinder, angle grinder and drill press. I think it manages to give a custom look while retaining a lot of the original elements.
