The gauges will mount right up to the triple tree holes. Both bikes use the same tree.
The difference that you will have to work on is the wiring harness that plugs into the main harness. The plastic plugs are a different size as well as having different type of wire ends in them. You could cut and splice the ends to match up the correct plug. I would soldier them and use shrink wrap to protect them from the water. It should be pretty simple.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
