1 - 20 of 24 Posts
As discussed in my new member introduction I purchased a 1981 CX500C, and began safety maintenance inspections after guidance from veteran members. I had noticed an oil leak under the motor when I initially bought the bike and thought nothing of it until today. After further inspection there seems to be a hairline fracture under the oil drain plug. The only front crank case replacement with a decent price is off of a 1978 CX500, would I run into any problems down the road if I used this as a replacement?
Always grateful,
Wreckbombed
Automotive tire Font Gas Plumbing Motor vehicle
Before I did that I would grind a slot at the crack and fill it with JB Weld.
If you use a Dremel tool you can make the grind wider at the bottom of the grind than at the surface to key in the JB Weld filler.
Perhaps drill a small hole at the end of the crack to keep it from spreading in addition to Thumpers suggestion.
That crack is from the drain plug from being over tightened. Mine was cracked on my Silverwing when I got it. I bought one from Ebay instead of trying to fix it. I would have to worry about breaking the fix every time I changed the oil or worry about it letting loose on a long road trip. The front cover isn’t hard to remove. I would replace it if you found one at a reasonable price.
Thanks for the input everyone. For now I’ll patch it until the new one comes in. Fingers crossed there’s nothing wrong with it.
Let us know if the "repair" works.
Reactions: Wreckbombed
You should find plenty of these front covers on eBay! :)
I haven't gotten around to working on the bike since the other day, I'll probably just buy a cover on ebay instead of trying to repair it. I'm not that skilled in wielding anyway.
As soon as it arrives I'll update y'all.
Stay safe.
If it isn't leaking too badly I would leave it the way it is and look for a replacement. Temporary repairs have a way of becoming permanent - until the part fails altogether (usually at the worst possible time).....
I thought that said 'wet' 🤣
Hey, now. This is a family show!
The pic was innocent enough when i posted it...
Discussion Starter · #19 ·
Well at least he didn’t say, “moist” below the picture.
update: no seals for the cover yet, hoping forTuesday.
Indeed, given the context, the fact that it is red coloured sauce is the worst aspect.
1 - 20 of 24 Posts
