A few months ago I dropped my engine and pulled the rear engine cover to replace the grounded A/C generator stator. I ended up replacing all of the rear seals as well, enlarging the water pump seal opening and using the Yamaha seal set. After reassembling the engine and installing it I have ridden around 1,500 miles without leaking a single drop of coolant or oil. Just yesterday I noticed a small wet spot under my CX500 after parking it for the evening. Starting it today revealed a small but steady stream of coolant originating from the weep hole.
Since I just disassembled and reassembled my engine, I'd rather not do it again if I can avoid doing so. Does anyone have any ideas of why this problem would suddenly surface?
