I'm doing a naked bike conversion on my '83 GL650i, and I'm switching to LED signals. The rear signals set up fine. Front set light up as running lights, but when actuated, just turn off on the side actuated. My understanding is this is because the stock lights use a double filament that allows on/off/flash and the LED has only on/off functionality.. Right so far?
My question is what is the fix to make the front LED signals run and flash? I have a LED compatible grounded flasher unit(2 prongs with a ground wire that is frame-grounded), the turn signal dash indicator works and flashes, and the rear signals work fine. The signals themselves have 2 wires coming out of them.
Thanks in advance for the help, and let me know if I can provide any add'l info.
-Josh
-Josh
