I have a GL500 That sat for eleven years. Now I am at the point of trying to start it. Couldn't get it to fire, so I took out the plugs to test for spark. As soon as I turn on the key both plugs start arcing. Can not hold on to the plug as they have juice running through them as if there was a dead short to the plug. When the key is turned off all stops. Does any one have a clue?
I am using a 12 volt battery charger with the battery in place, as the battery is dead.
Thanks Ken
Wow, I have seen this once in my lifetime, and that was on a 1920's era Packard twin 6.
Try hooking up a good battery, even a car battery via some jumpers. You should never try and start anything with a stone dead battery and a booster/charger, they can throw out some serious current when there's no accumulator to dissipate the current. You could use a portable jumper too, as those are basically a portable 12V battery.
With a little luck, nothing is fried and a normal current load may clear it up. Sorry I can't offer any more insight, as my experience with the Packard may not be relevant to the GL's.
There was a guy on here a little while ago with the same symptom,,I am not sure but I think a new battery solved the problem. I will see if I can find the thread.
edit;
I found the thread here
Well I got a new battery and that stopped the constant arching. Go figure. Started the bike up after 11 years. Idles at 2000 and runs rich. I think I might have put the choke cable on to tight and when the knob is down all the way mabe the choke is partially on. Is this possible? I am going to change the oil, filter and the antifreeze and take it outside to run for awhile.
Thanks for all of the help
That would do it. The choke also sets up a fast idle when it is pulled. I'm not sure how much choke it takes to do that, but you don't want any choke on after warm up.
