1 - 2 of 2 Posts
Hi CX fans!
I got an issue with swapping wheels,I had a 16" reverse comstar rear and reverse comstar 18 front wheel.
I installed a new set of perfect looking comstar ,in the back no issue, but the front wheel is giving trouble (is on the original fork and calipers), the wheel does not spin freely, it is hard and dragging.
To test i removed both brake calipers,same issue.
I don't seem to find the cause of this, are the wheels the same? Is the axle the same?the speedometer mechanism? I told there was 100% compatibility...
I will try to put back original wheel and axle to see if it improves...could this be caused by bad bearings in the new comstar?
Thanks!
Gabriele
1 - 2 of 2 Posts
