1 - 20 of 24 Posts
100 each side. Now what?
Discussion Starter #3
It runs. I brought the jets back to stock but the need to adjust the air mixtures screws on the bottom of the carb. Runs bad without the choke
Discussion Starter #5
compression is sitting around 100 and left side just a bit less. Didn’t see a change hot. Throttle was wide open.
Discussion Starter #7
I will ill open it up and check
The second part of a compression check is to add some oil to the cylinder. If compression pressure improves indicates a ring problem, if no change the a valve problem.
Discussion Starter #9
How much should I apply and what should I use to put the oils in the area. Should I pull the valve cover to do this ?
You shouldn't need to pull the valve cover, just remove the spark plug, add a teaspoon or so of oil. Easiest to add the oil with a syringe and tubing. I use the one used for measuring two stroke oil when mixing fuel. Crank the engine a few times with the plugs out to spread the oil then check compression again.
By the way, are you doing the compression test with both plugs removed?
Discussion Starter #11
I did it both ways. One plug in and both out
Discussion Starter #12
Put some oil in and it didn’t change the compression. 100 both sides. Wonder if it just need to be ran for awhile. Some mileage.
Discussion Starter #15
Compression equal both sides is encouraging.
Can you do a leakdown test ?
I don't have a leak tester yet. Might have to purchase one on amazon
Discussion Starter #16
Have you used the compression gauge on other motors? Wondering if that could be problem.
It was my friends. Brand new never used until me.
Discussion Starter #17
Yes It is encouraging that it is the same on both sides
Discussion Starter #20
1 - 20 of 24 Posts
