1 - 20 of 22 Posts
Hi All
Well the weather as started to turn cold other here in New Zealand, and unfortunately it seems my bike doesn't like.
For the last two morning it has not been starting properly, it seems not to be firing on one cylinder. I'm not sure which one yet. Once both are firing it's all fine.
In the afternoon on the way home, it starts fine. So I'm guessing it's cold related.
Any ideas of what to check? It sounds electrical. The battery is pretty new and is good condition.
I still have to installed the IGN CDI, just sorting out payment with Cobram. I guess the new CDI would help. Would the slightly faulty stator cause this?
I will have a look myself tonight.
Cheers
Curtis
They are both new plugs.
Do I need a different a temp plug?
It's not really cold here, maybe 10 degrees C in the morning.
She's all fine once started.
hey Curtis,yes electrics can make a hard start,but try this.............
kill switch set to off,full choke,spin the starter for 3 seconds.wait 5 seconds,do it again,but flip the kill switch to run after 3 seconds spinning the engine.
wont cost anything to try
no,regular,recomended plugs are fine
thats not the issue
Do I have do the kill switch thing everytime?
only if it works.
it wont harm anything.
i use this method,when iv been away,and havnt used my bike for 5 days.it starts a treat
Why does this work? Will the IGN CDI help?
Curtis,i dont know,not to be tech. specific.
it might be reducing the load on the battery.stopping half an ignition,then die.maybe a build up of ignitable fumes......then 3 seconds later,the spark arrives.
i do know it does work,especially when the bikes been laid up
A method I use
turn on fuel tap - wait 10 seconds
twist throttle 4 times - wide open
pull choke 90% out
hit starter button
usually do not have to wait more than 2 seconds for it to fire
maybe runs on one cylinder for a few seconds as well
sometimes have to blip the throttle if it wants to stumble,then push the choke in a bit when it kicks onto both cylinders
let it idle/warm up for a minute - push choke knob fully in or after riding for a minute or two
hope that helps
By the sound of it, it looks like I'm going have to get into a cold starting routine.
Last week, when it was warmer, I just pulled the choke full, hit the starter and hey presto started. Just dropping the choke by about half start after starting.
I'll try out a routine tomorrow morning.
Cheers
Curtis
Cheers
Curtis
Curtis,mine starts instantly as yours.the kill switch can be a great mate.jusy try it
Discussion Starter · #14 ·
You might have something there, as I have recently cleaned the carbs and reset the mixture screw.
I screwed the mixture in all the way and back out 2 1/2 turns. I have the anti tamper ones with the lugs on them (i.e. can't adjust them much, until bowls removed).
Which way makes the mixture richer? In or Out?
Cheers
Curt
Cheers
Curt
Out is richer.
You could also check to make sure the choke plates are closing all the way when you pull the choke button out.
Discussion Starter · #16 ·
I do think I need to look at the choke cable, I may have made installed it a bit too tight.
It doesn't cut off now until it's pushed all the way down. Whereas previously it would be off before pushing the button all the way down.
Curt
That did it, 81custom starting regime worked a treat.
Cheers
Curt
Discussion Starter · #19 ·
I didn't touch the choke cable last night, I didn't have anytime. I did turn the mixture screw out slightly to richen the mixture slightly.
I just turned the gas on waited, turn throttle four times, pull the choke out 90%, rather than full, then hit the button and applied a little throttle once going. Then pushed the choke halfway in.
It seems to be sorted, although I have to say that it was a little bit warmer this morning.
Curt
Curt
glad to hear your sorted
1 - 20 of 22 Posts
