OK, fellow CX500 fans, I am afraid I must be missing something obvious...
I own a 1979 CX500, purchased for $400 10 years ago, my first machine, and one I will never let go of. Found it in this town, not far from where I live, in South Ogden, Utah.
It has been running steadily worse every year, so I finally decided to do some work on it yesterday.
Sorry for the verbosity of the post, but I know how frustrating it is to try to help without knowing what's been done, so here's what I did yesterday:
* Checked compression on each cylinder, read 110 on both, almost identical readings so I considered that good.
* Pulled carbs, separated them.
* Found missing O-rings(the little tiny ones) on the little side air circuit that helps actuate the vacuum needle valves. Replaced with O-rings from parts carbs.
* Cleaned both internal jets with carb cleaner.
* Checked for smooth operation of needle valves, choke, throttle.
* Cleaned both fuel fill circuits and the connecting fill tube.
* Checked float level.
* Found broken O-ring on LH intake head flange, replaced with a good fitting ring (not Honda - but fit perfectly)
* Reassembled carbs and reinstalled, being sure to get boots securely on, no leaks.
* Pulled air cleaner, tapped to clear loose dirt (running about 5000 miles on this air cleaner)
* Checked spark plugs, replaced RH plug (this was the most problematic cylinder before I began)
* Noticed RH plug wire was loose in the L-shaped boot; Cleaned corrosion on the pin inside the boot, cleaned the end of the wire, and re-inserted the wire. (Should this wire not be detachable? The LH wire is not detachable.)
After all that, the machine started up and ran, but was still stumbling somewhat. I warmed it up to normal operating temps, then:
* Adjusted idle to 1100RPM
* Leaned mixture on RH carb until RPM drop, then back 1 full turn.
* Adjusted back down to 1100 & repeated on LH carb, and final idle adjust back down to 1100 again.
* Throttle had hesitation, but otherwise the machine ran fairly smooth.
Took it for a quick road test, too much hesitation, then:
* Attached carb sync tool, adjusted sync screw until they were balanced. Was slightly off, but not bad.
After buttoning it back up, the machine ran better than it has in years. Great.
So this AM, after resting overnight, I pull the choke and it won't start at all. I get a stumble or two, but it's almost like the machine is dead. This is how it started out yesterday before all the work, so it could be that while it was warmed up, all the procedures and tuning I did went fine, but when the machine is truly cold there is still some sort of issue.
At this point, since I know compression is not an issue, and I am pretty confident the carbs are tuned about as well as they can be (at least by yours truly,) I'm starting to lean toward spark. However, I am quite weak in the electrics side of things - so what do you folks think?
Thanks in advance!
-Jim
1979 CX500 Custom
Ogden, UT
EDIT - Forgot to mention, I picked up a new battery last week, fully charged. The engine cranks over quickly.
Thanks in advance!
-Jim
1979 CX500 Custom
Ogden, UT
