Are you gentlemen certain of this? The manual note agrees with you but the associated picture does not:Correct was for photo/test fitting only.
Could not the note be wrong?
Same chapter:
I believe that note is incorrect. Which model's FSM is that from? It would be worth comparing it to the others.Are you gentlemen certain of this? The manual note agrees with you but the associated picture does not:
'81-'83 GL500 GL650I believe that note is incorrect. Which model's FSM is that from? It would be worth comparing it to the others.
Visually, the correct orientation will appear backward, but functionally, it's optimal. The nut presses where it needs to press and the special socket engages as it needs to.Seems counter intuitive to me?
If the nut says this side out, That's my plan. Its been a while since I've been in a clutch but...All I have opened were with the large face out?Visually, the correct orientation will appear backward, but functionally, it's optimal. The nut presses where it needs to press and the special socket engages as it needs to.
