MATERIAL SAFETY DATA SHEET
PRODUCT NAME: Wheel Brite / Pro-Brite
PRODUCT USE: Cleaning steel surfaces FORMULA NO:121
SECTION 1:HAZARDOUS INGREDIENT INFORMATION.
Chemical identity Conc. CAS No. PIN No.
Sulphuric Acid 2-3 7664-93-9 1831
Hydrofluoric acid 5-10 7664-39-3 1790
SECTION 1V: PHYSICAL DATA.
Physical State : Liquid
Odour and Appearance : pungent and water like
Odour Threshold : none
Specific Gravity : 1.00 approximately
Coefficient of water/ oil distribution : Infinity
Vapour Pressure : not applicable
Boiling Point : 100 C for 1% solution
Freezing Point : 0 c for 1% solution
pH : 2.00+0.50
Vapour Density : Not applicable
Evaporation Rate : Not applicable
Percent volatile by Volume : Not applicable
SECTION V: FIRE AND EXPLOSION HAZARD.
Condition of Flammability : Non flammable
Means of Extinction : Water, foam or carbon dioxide
Explosion Data Sensitivity to Mechanical Impact : Not applicable
Sensitivity to Static Discharge : Not applicable
Flash Point and Method : Not applicable
Upper Flammable Limit % : Not applicable
Lower Flammable Limit% : Not applicable
Auto ignition Temperature : Not applicable
Hazardous Combustion Products : None
SECTION V1: REACTIVITY DATA
Stability : Stable under normal temperature
Incompatible Materials : Other chemicals
Conditions of Reactivity : None known to the manufacturer
Hazardous Decomposition Products : None known to the manufacturer
SECTION V11: TOXICOLOGICAL PROPERTIES.
LD50 Species and Route : Not Available
LC50 Species and Route : Not Available
Route of Entry : Skin contact -Yes
Skin Absorption -Yes
Eye Contact -Yes
Inhalation -Yes
Ingestion -Yes
Effects of Acute Exposure to Product : Not applicable.
Exposure Limits : Not applicable.
Irrintacy to Product : Moderate to eyes.
Synergistic Products : Not known to the manufacturer.
SECTION V111: PREVENTIVE MEASURES.
Personal Protective Equipment : Applicable
Gloves(specify) : Recommended.
Respiratory(Specify) : Required
Eye(Specify) : Necessary.
Footwear(specify) : Necessary.
Other Equipments(Specify) : Consult your supervisor
Engineering Controls(Specify) : Natural ventilation sufficient.
Leak and Spill Procedures : Absorb with sand and oil dry
Waste Disposal : Observe all Local, Provincial
and Federal regulations.
Handling Procedures and Equipments : Avoid using metal equipments
Storage Requirements : Store away from food
Special Shipping Information : Hydrofluoric Acid & Sulphuric Acid Mixture UN1786, Class 1, 8(6.1) (9.2)
SECTION 1X: FIRST AID MEASURES.
Inhalation : Move to fresh air
Ingestion : Do not induce vomitting, give milk and
seek medical advice.
Eye contact : Flush with water and see doctor
Skin Contact : Flush with water and see doctor.
ADDITIONAL INFORMATION:
Detergents are products made by blending different chemicals possessing different degrees of different hazards. It is difficult to determine the combined effect of these chemicals. Therefore discretion on the part of the Supervisor and operators are kindly requested. This product is highly acidic and reactive and must be used with adequate precaution. This product is made exclusively at the request of the customer and is not a standard product of XXXX Corporation. We are completely aware of the damages to living environment.
Sources Used : Merck's Index,TDG Act,WHMIS etc.
NON WARRANTY:
Prior testing for fitness for use by the purchaser and purchaser's compliance with applicable statues is a strict condition of sale. The information given above are prepared from our knowledge of the product. All recommendations and suggestions are believed reliable but should not be construed as warranties.
XXXXX Corporation disclaims any liability incurred in connection with the use of the product or the data given above.
