Has anyone had experience chemical dipping parts to remove paint and rust? I'm wondering if it's strong enough to remove POR-15 tank liner.
I called every furniture store around here trying to get my tank dipped - nobody would touch it even though it's just old enamel. I would imagine an engine rebuilding shop might be a better choice.
Why a furniture shop?
Or is that another name for a place that has Harleys.
Why don't you contact the people who make POR-15?
POR-15 also makes a stripper that works on other tank sealers, maybe it will strip their own product?
Their web page says this: "For those unfortunate customers who have had bad results from other inferior fuel tank sealers, we have developed these all new "HEAVY DUTY UTILITY & CYCLE TANK REPAIR KITS."
They feature everything found in our regular UTILITY & CYCLE TANK REPAIR KIT, PLUS a quart bottle of our famous Tank Strip to first remove that inferior coating that failed you."
http://www.por15.com/HD-CYCLE-TANK-REPAIR-KIT/productinfo/HDCTRK/
Why are you trying to remove POR15 anyway?
Gobears, You really should try the acetone. I just did a tank for a fellow member that lives in SF last week and it worked just fine. I just noticed you are close by. If you want to send the tank to me or bring it up I would be glad to help. I have the acetone that I used in Georges tank still. If you came up in the morning, I'm sure we could have it cleaned out and sealed by the end of the day. I have everything here we would need.
