i pulled my small springs out of the front forks today with the intent to either put in a preload spacer or, like Stitch suggested, replace the entire spring with a piece of pipe. with the pipe i couldnt get the cap on and i my saw blades are dull as hell. the spacer got jammed in the underside of the cap. so instead of getting new blades or more steel pipe, i rummaged thru my toolbox and came across two short 1/2 inch ratchet extensions and 2 matching sockets. put them together and fit them in. fit like a champ. i gotta replace the air line hose cuz the threads are shot. without any air and standard atf in the forks i got minimal sag under weight. so my question is... should i bother redoing it with something other than scrap tools?
