I have a 1978 CX500 with a charging issue. Last summer I was having issues with the bike cutting out under acceleration when it was hot out and replaced the CDI with an Ignitech unit and it solved the problem, bike ran better than ever. Last week I replaced the noisey, stock fan with the electric upgrade (Ducati fan, thermostatic switch wired to the battery with an in-line fuse) I took it out for a shake down run and everything worked great, fan turned on when it was supposed to and turned off when it was supposed to. I stopped for dinner and headed home and on the way home I noticed that the headlight was dim and as soon as I pulled into the garage it died. Tried to start it and it was dead. I charged it on a battery tender overnight and did some testing the next day. I tested the stator and everything was within range and checked out OK. I tested A/B, A/C, and B/C and all were 0. I also tested A/ground/5/neg battery terminal, B/ground/5/neg battery terminal, and C/ground/5/neg battery terminal and all were 0. I then checked the battery and got 13.22 when the bike was off, 12.30 with the headlight on and 12.33 at idle and 12.79 up to 4000 rpm. I assumed it was the R/R so I installed a new one from Rick's and got the same numbers after the install. I just rechecked the stator and now the 5/9 reading is 567, ran it through the online test and got "Some of the coils on your stator are faulty - if you are using the stock CDI you will need to replace the stator. The Ignitech does not require these coils to run." The battery is maybe 3 years old but is almost always on a battery tender when parked.
#1 - Since I have the igintech unit does this mean that I'm OK or do I need to replace the stator?
#2 - Is there anyone in the Chicagoland area who would be kind enough to take a look at it with me? I can pay you in beer.
#3 - Did the extra load of the electric fan cook something?
#4 - Is the battery OK?
Thanks,
Kurt
Thanks,
Kurt
