Alright, I understand the purpose of the H-Box. For this reason I intend to keep it on the bike. However, the megaphone mufflers of my 79 CX500C are in need of replacement. I don't like their look and would like to add something that looks a bit more clean (clean, referring to the look, not the condition). Would rejetting be required if I add different slip-ons, while retaining the H-Box and original intake system?
Everything in forums I can find about exhaust is people discussing the removal of the H-Box. I personally don't think it looks that bad but could see why others want to remove it.
Any help y'all could lend would be great,
Thanks.
Depending on what mufflers you decide to go with it may or may not be' necessary' to rejet. The only determining factor is if the engine developes a runability problem, usually a hesitation or bog. My bike retains the H-box and OE airbox , original mufflers with baffles removed. Jetting from the factory on all road going bikes from this era is too lean. Rejetting will increase overall performance even on a completely stock bike. Choose mufflers then test ride and see if you're satisfied with runability. If you want better acceleration then rejet.
