OK.........
I tried to bleed the brakes. I have some brake but you know the old story, I can't get a firm front brake. It does stop somewhat.
The bikes still sits up in the front a bit when parked. It sits level when I sit my 200lb. butt on it.
The handling is about the same. I think slow speed turns are better now. There is not as much top heavy feeling going through the turn.
The one thing I don't like is the fact that I don't have much travel left. Maybe two to three inches during riding.
The new seals are nice. I don't have fork fluid all over the bike when I ride it. Yeah.... the first set of second hand forks were that bad. The original bent forks didn't leak at all.
Oh yeah, the ride is great. It rides about the same as the original set up but with a little less dive.
So for the record, if you want to lower your CX in the front or you can't find any fork tubes for you 81 Custom, use the 35mm fork tubes off a CB650. Mine came off an 81' model.
