1 - 6 of 6 Posts
Hello I have a1979 cx500 and I made it into a cafe racer. I put pod filters and different mufflers when the moter is cold it runs really rough and it Boggs. Once it’s warm it runs better but still not perfect. Do I need to change the jets? If so what sizes. What can I do to resolve this issue. Thanks
How did the bike run before your changes? Did you remove the H-box? Some pods have an inside lip which can affect the carbs by partially blocking the atmospheric ports. Pods Plug Atmospheric Ports
1 - 6 of 6 Posts
