1 - 10 of 10 Posts
I am restoring an 81 cx500c. I am an amateur, so decided to get a repair manual. Decided to take carburetors off to clean them, before receiving the repair manual. I separated the two carbs, only to find out the repair manual says its not nessasery. So I have cleaned the carbs and trying to put back together and realizing it was a huge mistake. And when I pulled them apart, a bigger spring went flying. I have no idea where it came from. Am I gonna be able to do this?
208954
Which manual did you buy? I highly recommend Larry’s Carb book. If you read his book you will most likely be tearing your carbs apart again to clean them properly and you will be able to put them back together following the directions in the book. Many others here will chime in with the same sentiments.
GL650
Buy Larry's carb book. Before you do anything else. Believe me. And be ready to go slow and follow all the way through. It's intricate but after the first set you will have acquired a valuable life skill. And you'll find you probably dont have them as clean as you think. Dennis Kirk and David Silver Spares have the parts you'll need. Peace
That spring can be manipulated back into place in a few minutes without separating the carbs again.
Takes 30 seconds if you hold your mouth right.
Pinch the spring down short and fit it to the little projection on one side and push it in to the gap.
208969
Note that I have pointed out the choke side as this is what is visible in your photo. It actually fits in the same position on the throttle side.
1982 GL500i
Randakk's has the best replacement seal kits and instructions for these carbs, as well as petcock kits.
Reactions: Retroben
THANK YOU!!!! Greatly appreciated!
When the manuals were written they weren't really expecting many people to still be working on them 4 decades later. If nobody else has ever separated the carbs they are likely to still have the original o-rings on the pipes that run between the carbs and 40 year old rubber that spent most f its life in contact with a strong solvent (gasoline) isn't to be trusted so separating them now to replace all of those rubber bits is probably a much better idea now than when the book you have was written..
Note that the FSMs for the CX family are particularly well written and laid out so they are a far better reference than any aftermarket book (Larry's carb book being the exception). Clymer manuals in particular are notable for the number of errors in them (the one for the GL1000 tells you to reverse the locations of the 2 jets!!!)
Thank you all for your comments. Now I gotta change oil and filter, change spark plugs, replace some fuel lines and battery, they see if I can start it. Wish me luck.
I had also bought a carburetor repair kit, but ended up leaving most parts in the carb. Mainly because the pieces didn't match exactly. I did replace o-rings on the tube, and replaced the gaskets for bowls. Not sure the last time this bike was running. Gonna need a lot of TLC. But over all it looks great. Very minimal rust. Havent even gotten it to turn over yet. I did hand crank it and seemed smooth as butter so......fingers crossed
This is a good sign. A lot of people figure if it came in the kit they have to use it whether it is the same or not and then can't figure out why (for example) the carbs overflow with the new, shorter float needles.
1 - 10 of 10 Posts
