1 - 6 of 6 Posts
Hey everyone!
I'm working on a 79' Custom. As is with older bikes, especially not well maintained ones, the old, original carburetor insulators (boots) cracked. Normally I just order an OEM replacement and move on. However, while Honda still manufacturers the right insulator, the left one is no longer in production (as I'm sure some of you have run into), and so far as yet there seems to be no equivalent available. I always prefer using OEM or equivalent quality replacement, and wonder if anyone has found one for the left insulator. I'd much rather not use hose and clamps to fix the issue, as that seems unreliable and at best a short term solution. If anyone else has found a better way, your help would be much appreciated.
Thanks!
^^ and might as well get both sides at that price, then no worries
Although not as good as a new replacement, I purchased the right size heat shrink tubing and covered both tubes on my CX650E. It looks pretty good and functions well so far.
1 - 6 of 6 Posts
