1 - 7 of 7 Posts
Me again...
Got bike running of sorts after standing for x years but its not very happy....looking at plugs (both replaced and gapped right along with new HT leads and caps ) it shows both black and soooty even thought choke not used (or needed ) to start and not sticking on.
Have removed both float bowls and blown through all jets twice and still the same...removable jets and jet holder all clean as a whistle...
Air filter clean and no difference when removed completely....
Any suggestions where to go next other than for therapy.....?
Thanks in advance for suggestions....
Check your float levels 'on bike' using 4 mm clear tube on the drain nipple. Hold this up the side of the carb with the petcock on and it will show the fuel level. Should be a couple of mm below the carb/bowl joint.
Restricted exhaust.
Weak spark.
Did you ride the bike at speed before examining the plugs? You can't tell much from looking at the plugs after idling because the mixture is always a bit rich at idle. You can usually get an indication of what is going on by looking at the plugs after a bike has been ridden but to read the plugs properly you need to run it at speed steadily for at least a couple of minutes, then turn the kill switch off, pull over (no idling!!) and examine the plugs right away.
BTW: Please follow the instructions in the Forum Settings link in my signature to add your bike's model and model year (NOT year first registered) to your signature.
Don't know what model you're running, but if your float levels check good and you have a vacuum fuel petcock, check the diaphragm in the petcock. if it's ruptured, engine vacuum will draw fuel directly into the carbs. Usually indicated more on the right cylinder.
Dan
1 - 7 of 7 Posts
