1 - 15 of 15 Posts
'80 CX500C
Hey guys, just bought my first CX - a 1980 custom.
I've had a read-through found a link to Larry's book. While I'm waiting for that one to arrive I've got a question about side air valves. The one in my kit does not have a bulb of the original (see below)- will this affect the performance?
208235
BTW: Those are the air cut valves (sometimes called air cutoff). Learn what they do and why you don't really need them here
BTW: Welcome to the forum. Please add your location and your bike's model and model year (NOT year first registered if that's what the paperwork shows) to your profile so that you don't have to remember to tell us every time and we don't have to keep asking when you forget (see Forum Settings link in my signature).
'80 CX500C
Thanks Bob. I already learned about replacing rubber parts the hard way! I'll make those changes to my profile
Hey welcome.
You might of posted an intro somewhere else....(and I missed it)
Hopefully that Melb lock-down will end soon....and bikes can get back on the road.
good luck with the project
I've had a read-through found a link to Larry's book. While I'm waiting for that one to arrive I've got a question about side air valves. The one in my kit does not have a bulb of the original (see below)- will this affect the performance? View attachment 208235
What is this “Larry’s book” of which you speak?
1982 CX500C (US)
Most of the cheap eBay kits include the wrong ACV diaphragms (without the bulb) for the CX500
208350
In other places, Bob, you've argued that if Honda included something, it's there for a reason. Why should the ACV be any different? Why would Honda have added such complexity if it's unnecessary?
Because of the overly lean mixtures necessitated by emissions regulations of the time. Have you read Mike's article about bypassing them? I figure if someone who has written several books on rebuilding Keihin carbs recommends it they are no longer needed.
I have also described how some things like the throttle return cable and the GL1000's "reserve lighting unit" should be eliminated because they cause more problems than they prevented. The air cuts fall into the same category.
1 - 15 of 15 Posts
