[quote name='danno' date='01 May 2011 - 07:38 PM' timestamp='1304300288' post='67646']
I just got an 81 GL500. It does the same thing but hasn't run yet. I thought I'd write this before I do the carbs.
Where have you guys found the best deal on carb kits, i.e., most complete, best quality, best price.
Next.....and I can't think of a better place to put this.....
Both of my other GLs run well but have a notable lag of go on the very low end, Just starting off in 1st. gear they lag a second and as soon as I begin to open the throttle they leap forward. Is this common to the CX-GL carbs and has anyone figured out a way to make the transition from idle to low speed without the sudden lunge ?
I was imagining longer transition slots in the throttle bodies but wouldn't want to mess up my carbs unless it was on proven advice.
Thanks Gang
I am by no means a carb guy, but thats is not normal sounding to me, both my CX500 and GL500 were/are not showing any signs
of lagging off the line, sounds maybe like air jet? Dirty carb? Larry....calling Larry....where are you?
