There was no blue from the factory.
The engine speed increasing without a corresponding change at the wheel would be clutch slippage. Did you service the clutch cable as you did the throttle?
Failure to idle down is typical of running lean. Completely stripping the carbs and a good ultrasonic cleaning will likely resolve it. Look for Larry Cargill's book on the subject.
Unless the rubber parts are hard, you won't need kits. The bowl gaskets are most likely to need replacement, and they can be bought individually. If the Air Cutoff Valve diaphragms are leaking, they can be bypassed.
Thank you. I did not know that there were no light blue GL500's painted in the factory. I recently saw a blue GL1100 from the 80's and the blue paint looked similar. I just assumed that since the color of my bike was nearly identical to a GL1100 that I saw on social marketplace, my blue paint was original.
I did not service the clutch cable. The pull is surprisingly smooth, and I have tons of cable up front because the front fairing was removed. While I do believe a strippiIng/rebuild of the carbs will get the GL up and out on the road again, I am extremely busy and do not have time to research literature on the subject. I understand the engineers may have worked tirelessly to perfect the GL carbs, and I would like to learn how to restore them to working order, but my schedule will not allow it. Thank you for your help and suggestions, however, I am leaning towards buying a new carb set and devoting my time and energy to other issues unrelated to carburetion..I feel bad for giving up on the old Kline, but I would rather move on. I am unsure if the new carbs will fix the issues that I am having with the bike. If the new carbs will help the engine run better and the fuel system allows me to ride the bike comfortably across town a time or two, I will consider the carb modification a success, and I will start focusing my attention on other mechanical issues.
I am unsure of my next step. I guess I will weld the hoop, find a suitable seat and ponder my next move.
