I just bought a 1979 CX500 and I have a few questions about the carburetors.
1. When syncing the carbs where do you start? Do you adjust the mixture screws first and then adjust the carb sync set screw?
2. How many turns out do you set the screws to? The previous owner new very little about carbs and messed with both of the screws so Im sure they are out of whack.
3. The fuel valve started leaking when I was cleaning out the gas tank. Is there anyway to take it apart and fix it? It seems like there is probably an o ring that is rotten and it could easily be fixed if I could take it apart.
4. And does anyone know what size adapters I need to check the vacuum pressure? Is it 5mm or 6mm?
Thank you!
Thank you!
