Alright, I think I've established that I don't have an accelerator pump on the bike. I've ordered Larry's book for further research. I'm now curious as to why the carb kits from different manufacturers have different part lists. For instance on siriusconinc.com,
K&L CX500 kit lists
float gasket; float needle; both main and slow jets; air screw and spring; misc packing and gaskets and "O" rings as shown
CX500 Keyster kit lists
float gasket, slide needle and needle jet, float needle, #78 and #112 main jets, air screw, spring and misc packing as shown
(the float needle looks different, but otherwise these two kits are the same). But then
Randakk's Master Kit lists
Viton O-rings:
2 - fuel (idle) mixture screw (2.8 x 1.1 mm)
2 - float bowl drain screw (4.3 x 1.3 mm)
2 - CV Slide Top Limit Plug (6.9 x 1.3 mm)
1 - Accelerator pump passage at float bowl (5.0 x 1.3 mm)*
2 - Main Fuel Transfer Tubes (5.8 x 2.0 mm)
2 - Accelerator Fuel Transfer Tubes (3.8 x 2.0 mm)*
2 - Intake Manifold (40 x 2.6 mm)...slightly thicker cross section than the OEM specified o-ring for better fit and function
* as required
2 - Float Bowl Gaskets
2 Air Cutoff Valve Overhaul Kit
1 Accelerator Pump Overhaul Kit
2 idle mixture screw washers
6 float bowl screws (4 x 16 mm)
1 mm cotter pin for accelerator pump linkage - 1 supplied (simple item, but hard to find elsewhere)
2 Viton rubber blanking plugs - cover access to idle fuel jet
which is a markedly higher number of parts, but the float needle is conspicuously missing. Is this insight into the cleaning process? Should I not need to replace the needle if cleaned properly (ultrasonic methods or otherwise)?
