I'm in the middle of a carb clean process and either I have lost or they got chewed up somewhere along the way 3 O-rings. The schematics don't show these relating to a certain size, just that they are there. The 3 missing are noted below,
1) Vacuum Passage O-Ring
2) Idle Adjustment Needle O-Ring
3) Drain Screw O-Ring
I have a very good local source for O-rings, I just need to know the sizes for the three. I have one of the Vacuum and Drain screw so if needed I will use those as references, but the Idle Adjustment (which I do have, what's left of it) is toast.
You know 10 years ago I would have done something like this blindfolded, Nowadays it seems everything I am touching ends up screwed up. URGHHH!!!
