Carb Dril Bit Sources
1272 Views 13 Replies 6 Participants Last post by  RAFster122s
Larry's carb book recommends a couple of tiny drill bits that are numbered drill bits.
Xacto sells a 20 piece tiny drill bit set that goes for $33.99 +shipping that has the sizes one would need. It is decent carbon steel and has a small footprint case with the drill bits.
Squadron Tools (squadron a huge plastic model kit seller) Has a 20 piece set of numbered drills from 61-80 for $11.29
Zona (owned by same company that makes Foredom which is big in powered shaft rotary carving equipment) sells their 20 pc numbered drills for $24.39
squadron bits
Xacto bits
zona bits
Had I known the Squadron were available so cheaply I would have ordered them from Tower.
Probably all made in China.
Here's a link to look up the numbered drill bit sizes in decimal or metric. numbered size Xref
The 0.018 drill bit is a #77
The 0.031 drill bit is a #68
I don't have my book handy to see if there are other bits needed...
Hope this is helpful.
1 - 14 of 14 Posts
These tip cleaners do a great job and are very cheap and easy to find in a tool box.
http://www.google.com/products/cata...=X&ei=YWgxTuiICc7PgAf9l-SbDQ&ved=0CEoQ8gIwAQ#
Most Hobby Shops will have the bits and sell them individually. If you buy those sets, you will be paying for a lot of bits you will not likely ever use. I wrote down the numbers for the ones Larry recommended, and bought a spare of each. I think they sell for 1.99 each at most shops, some are sold in 4 packs in case you break them.
I also picked up what is called a pin-vise to hold the bits. It is an aluminum collet arrangement basically with a wooden ball type handle--worked great. Larry showed a Hemastat, this works too, but I liked the pin vise much better.
though I have never used these, many of you have with success, I like the control you get with the drill bits versus scraping that I can imagine you might get with the wire??
One thing these tip cleaners can do that the drill bits can't is that you can bend the last 5mm of the appropriate sized tip cleaner at a 90 degree angle to get those 3 little holes in the bottom of the main body under the throttle butterflies.
I'm not biased, I use both.
I've also been using interdental brushes which are like tiny bottle brushes.
I've been using the snipped off ends of my Guitar strings for years.Never a problem
Do you have to wear the makeup for the K.I.S.S. principle cleaning Shep?
No but you might
I know you like the strings...do you fish the guitar strings through the carb body ports to clean them? I did not do this on my last rebuild but might on the next go around. The jets and brass bits are one thing, but the actual carb body ports...thats another!
I use then down the Brass venturi from the top and under the Black Banana and the E or B strings into the holes either side of the Throttle plates but also blast through with Carb/Brake cleaner during and afterwards just to make sure fluid flows through all of them.In other words no matter what I use I check with Carb/Brake cleaner that fluid can flow where it's supposed to and nothing is blocked
I NEVER use them in the primary and secondary main jets.I just boil them in a pan with a bit of washing soda crystals/washing up liquid and then high pressure blow out
I haven't gotten my bits yet, but I did write them down to search eBay.
From Larry's description, we need the following sizes:
.085 = #44
.042 = #58
.040 = #60
.039 = #61
.031 = #68
.026 = #71
.024 = #73
.018 = #77
The welding tip cleaner for the holes under the throttle plate is .023.
Thanks for the links.
R
Squadron has a website and sells it for a bit more, so even though the shipping is less at Squadron it is a little more expensive for me than Tower Hobbies.
But that might not be true for everyone.
Here's Squadron's website link to the drill bits for $13.48 Squadron drill bit set
1 - 14 of 14 Posts
